Simple washer/spacers on the lathe video!
Making larger washers and spacers on the lathe, another method (-:
Begin with a rough cut disc, turn the jaws on a 4 Jaw for OD holding.
I place dowel pins in the jaws to get the part out for OD turning.
Face then turn the OD right up to the jaws then bore the ID, flip the part 180 Deg. and indicate the bore to zero, if the hole is large enough I indicate the back as well and knock it around until there is minimum run out, (place scrap aluminum or copper strips between the finished portion and the hard jaws).
Turn the remaining OD then face t0 length, done
