Wow! Very nice work. I have not seen a model fuselage built up from steel tubes like that before. The construction looks like a full-scale Cub.
I toured the Piper museum in Lockhaven PA last year. The factory is closed of course, but the buildings are still there. That is where they built the Cubs - from the J3 to the PA18.
The Bob Nelitz 1/3 scale plans are exact scale. His design just used brass tubing in the area of the landing gear connection points and some steel tubing in the wing support area. I just decided to be sure and went nuts on steel tubing in critical areas.
WOW.....this discussion took a weird turn,from silver solder to model planes .Tipical H-M. I would love to see the finished plane. I want to bond HSS toolbits to metal with a strong bond. Back when I used to work for a boss,we used flux coated silver solder with a acetylene torch set not too high,but that stuff is too exciting for me. I need something cheaper,but with strong bonding capabilities.
