- Aug 3, 2017
- 2,419
Note that you also want to leave a bit of room in the 'expanded' diameter so that the two "drop fit" together. If you were to make your difference exactly .165mm (~6.5 thou), you would need to 'press' the two together, which likely cause it to not work (since the shaft would be warming/outer diameter cooling).Thanks for all the replies and comments
I found this formula from another forum .
is this a valet quotation
δ = R×α×(T - To)
Where,
δ = change in radius
R = radius at room temperature
α = coefficient of thermal expansion (11x10-6)
T = elevated temperature
To= room temperature
If I use this, then the delta diameter is 0.165 mm
