109 Craftsman and Dunlap Lathes. The before is the Gray Craftsman lathe, the Dunlap was just more oil and grease. Both taped up and sand blasted and re taped again then painted.
I have quite a few, delta wood working machines, drll press, jointer, wood lathe, unisaw. 26" silver band saw, craftsman 12" metal lathe, rockwell 11" metal lathe.
Here are some pics of the craftsman metal lathe
I used Evapo rust to de-rust. Aircraft paint stripper for paint. I had to buy one gear change bracket, 14.00 on Ebay. I also replaced a bearing and the belt.
