- Apr 24, 2013
- 714
Working on the press arm.
Got the ends welded on. There will be UHMW PE on the inner surface of the ends to ride on the columns.
The ram will be screwed into an adapter that bridges from the underside of the channel to the plates welded to the face.
Threaded the adapter with 3/4-10 to accept the ram.
That way the ram can be replaced with specific tools as needed.
Only wish I had thought through the material for the adapter. Putting 3/4-10 threads into 4340 pre-hardened material was not a lot of fun.
Ram should be easier. I will single point the threads. It is made from Stress-proof so should cut nicely.
A little more each day.
