Shop Press Jack Location
For those with small shops, have you considered arbor presses? They seem to be available used on Craig's List and E-bay. They are small and compact and can be moved to a shelf under the bench when not in use. Maybe another option for you.
I'm also one of those folks with a small cramped shop and found an old 3ton arbor press off CL for $35. I don't use a press very much and so it has done enough stuff to warrant being permanently mounted on a work station. But it's still not a hydrolic press....
I do not have an arbor press, but at times that seems like it would be easier than a full size 20ton press. But some of the ones I have had to do the arbor press would not have made it happen.
You clearly need "the both." ;)
If I where to build a shop press I would use a ram not a jack.
I've used both of the designs and neither is as good as I guess you would call it the direct ram style. Tony Foale on Homemadetools.net did a real interesting thing, taking a common bottle Jack and modding it to become inverted to be a direct ram type. Much simpler and less likely to bind like either the over or under design. He has a pretty good write up Here
Thanks, uh, Cbag. I appreciate the link
