- Feb 22, 2013
- 159
So I just bought a new house and will be moving in at the end of the month. I'm currently renting the one I live in now and my basement shop has a vinyl tile floor that was put in 26 years ago. It's held up perfectly fine except for the normal paint and abuse stains. It is just glued directly to the concrete floor. Nothing fancy. So now in the new house I have a half finished basement. One side is vinyl floor and is a family/tv room and the other half is utility with concrete floor and that's where the shop will be. So now I have options. Put down a vinyl floor like I have now which is cheap OR go with the fancy expensive epoxy coatings. The only thing I'm worried about the epoxy coatings is the prep. There apparently needs to be a lot of washing of the floor and etching with acid. Seems fine for an open area like a garage, but I have a sump and drain around the perimeter of the walls and don't want that stuff going in it. Also there are finished walls on portions of the cellar. Plus I assume if you don't get this step right your looking at a crappy finish or worse a peeling floor.(that's what always happened in our shop in highschool) I only have one picture so you can see the floor condition. I'd like to get some opinions from people who have the floors. Were they hard to put down? Do they last? Do you still have your arms legs and kidneys or did you have to sell them to get the floor?
