- Jul 28, 2017
- 2,555
Many plastics are very abrasion-resistant. On top of that, you can get some some that have added molybdenum disullfide so they have built-in "lubricity". I bought some MDS-impregnated nylon specifically for making gibs but haven't got around to making any yet. I bought it from McMaster-Carr. The cast stuff is less expensive than extruded but it's a little rougher due to being sawed up after being cast. It machines quite nicely -- I learned that when I made some carriage slide plates with it. Dick "Old Toolmaker" recommended it.Although having never used any Sherline products, I have a gripe about the plastic gibs. Yes EMCO had them in the Compact 5, a lathe considerably larger. But wouldn't it make more sense to create gibs out of brass or even copper? I have an old Edelstaal Machinex 5 and even it has brass gibs.
One downside to using plastic is that grit can become embedded in it, causing it to become more like sandpaper. So it's important to make sure that all the bearing surfaces are very clean.
