well, at least the steady and follower rest look servicable Was this lathe stored under the sea by any chance?
Good luck getting everything back into shape.
A little bit if surface rust. Big deal. And everything's there except for a tool rest. They must have had a shaper at one time too, judging by the tool holder in one of the drawers.
By the way, nice Ford
it's certainly very well tooled! Hopefully it's just surface rust on the precision surfaces, in which case a butt load of time in the electrolysis tank, some scotchbright and some paint and you'll have a lovely lathe. The backgears certainly look in very good shape. I presume that a rebuild thread is on the cards?
You bought it! It will clean up and make a very nice machine, it is a pity someone didn't grease it down and sheet it, but there you go. Get stuck in and have some fun. Surface rust on cast iron, no problem!
Phil
