- Aug 3, 2017
- 2,437
I've been meaning to do this project for a while (or something like it!) But until @lesrhorer asked me to cut a keyway for him, I didn't have the motivation.
Traditionally there are a few ways to make an internal shaping tool, but they tend to have the downside of only working with a single size bar, which limits the jobs you can do. Like a lathe boring bar, you want it as thick as possible to resist flexing.
I saw Fireball Tools do this project, which is to weld a 5c collet block to a bar and use that instead! I had also recently acquired a spare collet block set, so it was basically kismet. This makes it so I can use the cheap and highly available lathe boring bars of any size I want, up to the 1 1/8 5c collet I have.
First, I went to the local shop and picked up some 1"x2.5"x12" stock, which I then flattened and squared on the shaper. The small ends were done on the mill.
Then today, I spend a few minutes setting it up and welded it together. Looks like it will work a treat!
I DID screw up one thing, the set screw for the anti rotation pin I managed to get facing the wrong way, so it is now inaccessible. I considered cutting it apart and starting again, but the screw is retracted completely and hopefully won't cause problems in this configuration.
I also left the bar a little long, I might be cutting it down in the future if it is a problem.
