need to practice my squaring, I've tried the work face, and squaring off of the chuck face with the blade.
Also, don't trust the holder to be square with the blade. It may or may not be, depending on how closely the blade and holder mate.
Likely the parting blade is flexing a bit when facing, which I would expect. Its thin.I used a chuck bubble level, and the results were a little better. I manually fed the cut off, and dropped the piece with a .040 nub. I did a second part advancing very slowly in the center, and the nub was .020. Just doing a 1/2 blade width facing cut made a smooth face, but I noticed it still was shaving a little coming out, and going back in without making any adjustments. What is causing that, and do I chase the height more, or is the nub situation within tolerance?
