- Jan 25, 2015
- 2,558
I'm in the process of redo-ing my little sewing "nook". It involves making a new "C-shapped" table to mount several machines to.
Space as it currently is:
Pardon the mess. There's a couple projects going on in there right now.
I'd like to make three of these machines "retractable" (fourth machine is an industrial walking foot machine, full cast iron and too heavy to "retract"), but not "flip up" like the traditional sewing tables.
I'd like to build a power lift mechanism, something like this:
Those are prohibitively expensive as you have to buy the whole table.
I'm thinking a gear and rack on either end of the lift platform driven by a central motor so both sides rise evenly.
The question is the rack and gears.
I'm trying to decide between 3d printing them or machining them out of steel.
3d printing is easy, I'm just concerned about strength. I'd be using ABS to print.
Steel is a different story. I've got the lathe and mill, but I've never cut a rack or gears before. Is it a hard skill to learn?
I thought about just buying pre-made rack and a couple gears, but we're back to it getting pretty expensive for just the gearing.
Thoughts anyone?
Thoughts anyone?
