Setup for cutting two 6 foot x 1/4 inch key ways
Mike,
Probably the best thing I can do with the horizontal mill attachment would be to set it up for a test run and
see exactly what it is capable of. It's possible that the cutter I tried was not up to the task. I have used just the
angle attachment part with an end mill and that works fine. It's not a tool you want to use often because it
requires quite a set up effort to use.
