If they are flush then follow the suggestion in the video I linked, or if your talented with a grinder and can clean the dust out well then follow chips&more's suggestion. If you stack the bearings as noted in the instructions you can see if they are flush or not immediately. they shouldn't be able to touch. With preload touching is optional although I discourage it.
