- May 27, 2016
- 3,479
Just thinking this through a little - starting with the artificial impossible. First imagine the perfection of a drill, and zero run-out drill press, and infinite stiffness, and utterly symmetric cutting faces, etc. and then play through all the things that can start the tip doing a little twirl. Consider why the hole being cut is, at some points down there, temporarily not exactly "round", and able to head off course. Different case, I know, but it begs the question of how the oil drilling guys can "steer" their drill bit to places not exactly below their start point.
It's a good start to use a spotting dill, that being short and therefore stiff and uncompromising.
Maybe shift up so that the quill is extended as little as practical at the start of the hole-making.
But then I think, the one thing that that will limit drill flexing, and wandering about, is to force it to stay straight. Maybe drill a hole in some thick(ish) steel, and put it onto the drill bit before lining up. Then, with the bit where you want it, clamp on the steel guide, and drill some of the hole deep enough to become it's own guide. Test alignment gently at first, or things might snap!
I don't really know. These are just thoughts about what I would try in that situation. Coincidentally, for myself, I am currently trawling catalogs, and "reviews", and eBay, and Machine Mart, etc. checking out drill presses with a view to ending up with something that won't disappoint!
