- May 14, 2015
- 179
Well, I've 'gone that route' since those two units are on the way here, for 390$ used (not bad, assuming I find a decent cabling solution)That Baldor is a beauty and, as usual, expensive as hell. One thing about this motor is that it is actually a permanent magnet synchronous motor, a cousin to the brushless DC motor but with sinusoidal rather than trapezoidal BEMF. You can't do much better than that motor, it is pretty much state of the art. Looking forward to seeing it in action, if you decide to go that route.
So, as my last question for those with experience, if I'm running my spindle servo via step/dir like my axis stepper motors, and I'm using the servo's encoder feedback to ensure the spindle is following steps, do I have the control/coordination needed to do threads/tapping from an off-the-shelf unit (let's say Smooth Stepper for argument), or is additional feedback to the actual motion controller necessary? From what I understand it absolutely is in the case of the speed control "spindle" output these cards have (the +/- 10VDC analog signal*) to bring additional encoder feedback to the motion controller so it can make double-sure the feed axis is keeping up with the rotary, but what about the same maneuver between two proper stepper drives, assuming no missed steps? If so, then I need to make sure to use a controller that can parse the simulated encoder output of the servo driver.
TCB
*That output may ultimately control the spindle of a live tool, I think
