- Dec 18, 2019
- 7,495
Recently picked up a small 0-3mm Albrecht chuck and Jacob's arbor with the idea of making a sensitive drilling rig for my lathe. Here's a CAD picture of it. Originally I thought I'd try a MT3 taper to go directly into my tail stock, but I've given up on that idea, since I've never made a Morse taper before. Hopefully this is a little easier to implement. It has a 1/2" shank so I can fit it in my existing drill chuck. I'm using a 7/8" diameter piece of 1144.
I'm not sure how well this will work, but it's worth a try. The Jacob's arbor mics at 0.4995" or so, so I'm hoping I can ream the hole to 0.5000" for a decent somewhat snug sliding fit. The design is sort of based on Joe Pie's video, or my distorted understanding of it. If it works out, I'll attach the drawings in this thread. The little hole in the side is to let out the air, as the arbor will form a piston in the sleeve. Due to the center section of the arbor, it will support drilling holes only 22mm deep, (the outer section is 23mm long), but this is good enough for tiny holes that I need to do.
