If your mill has rigid tapping capability you don't need a tapping head. Whether you go with rigid tapping or a tapping head a 0-80 tap is going to be a dicey undertaking.
Tom S.
Your luck sounds like mine. From good to bad.
0-80 in Ti?
Step 1: Buy a big wheelbarrow load of taps.
Step 2: make sure you have no blind holes or at least a way to those broken taps out.
Step 3: Remove all time constraints from the contract or P.O.
This i going to be a process.
In Al, it would be an undertaking. Not just because of the size, but because of the setup. The rigidity of your tooling and machine will matter. The accuracy of your motor will matter. You will probably want to "sneak up" on the holes from the same direction each time to preload the bearings (yes, it's a thing).
Then when you get to Ti, everything is amplified; every shortcoming comes up worse. And everything that took minutes to do now will seemingly take hours.
Don't count on this running automatically. This will need plenty of babysitting, IMO.
Wrat
Hi,
I got one of the generic ones when I was building my router. I had 50 3mm holes to tap in 1/2" aluminum.
I broke a tap in the third hole, but that was due to my not having the parameters set properly in my cam. Once I figured that part out,the rest went with absolutely no problems. I figure it did a much better job than I could have trying to hold the tap straight by hand:{)
I don't use it often, but sure is nice to have when I need it. IIRC it is a Taco brand made in India I think, not sure where I got it but it might have been from Enco.
With a thread form tap drill to 55% effective thd. dia. and make sure your form tape can vent. This thread will be stronger than, if I remember correctly a 72% effective thd..
The form tap should help a lot with the blind hole issues. I think what you really need is the best possible quality tap and the best possible threading lube for the job, not to mention tight control of the tap, Keeping it in line with the hole and letting it slip in the driver if the loading exceeds a safe load -- and some good luck! Also, as suggested above, consider a larger hole and lower percentage thread depth.
