- Jan 22, 2011
- 8,016
Absolutely correct, Bill. My recommendation was to run 0.0002 tight. Same with the shaft. 0.001 tight on the shaft is too much for that size.
All bearings, of this type, have built in clearance. This is needed to prevent galling when the bearing gets to operating speed and temperature. As a general rule, most press fit applications require one thousands of an inch--per inch of diameter, but I have never used this rule with bearings. Most bearing applications have a (slip fit) meaning that they can be pushed in or lightly tapped into position. If there is a chance of the bearing working out, I would fabricate a retainer of some type.
