- Sep 19, 2011
- 42
Folks,
I have a project I'm working on where I need to install a bearing into a pocket on a plate and then a shaft through the bearing. The bearing is .5" OD x .25" ID ball bearing, pretty similar to what you'd use on a router bit.
My plan is to mill a .495" pocket in the plate (CNC interpolation with a .25" end mill?) to accept the bearing and to turn the shaft to .255". Both shaft and plate are 6061 Al. Then I was planning to heat the plate in an oven to about 200F and push the bearing into the plate with a 1 ton arbor press. Then I was planning to cool the shaft either in the freezer or with dry ice and push it into the bearing with the same arbor press. During the latter operation, the inner race of the bearing would be firmly supported from below.
The project requires three such components.
What do you think?
What do you think?
