Yes, I need to replace the filter bowl assy, found it leaking.
Flushed the flex lines out with bucket, detergent and little submersible pump. Unfortunately can't do the same with the built in and buried lines around here, but I'll live with it.
This comp holds about 3/4 quart of oil, and never seems low.
The "auto" drain valve installed a year or so ago is crap, doesn't drain much and when water gets into it's tiny orifice doesn't drain at all. Soooo , hooked a short line to the drain port on the tank bottom reaching up to where it's accessible, and capped it with a cheap blowgun. Just squeeze and it dumps.
Pretty sure the whole thing will outlive me !!
