- Oct 24, 2014
- 208
Hi all I have a sears two cyl air compressor, probably 40 years old at least , about a 15 gal tank. . Dont use it a lot, It's on 3rd motor now and mostly runs/ran? well. A month ago I thought there was a lot of moisture coming out when blowing off parts etc. Turns out what was coming out was a chocolatey mix of water and oil. I have an auto drain on it and noticed that was sticking open. Removed the assy, found it gooped up....so I repeatedly filled and vented the tank. Same crap came out, but not that much really. Maybe a shot glass or so? Put it all back together and ran it a bit again. and found the same stuff coming out the nozzle. Seems like it's going into the tank as a fog or something and coming out as I use the air. Went to Harbor Fright and got a cheap replacement, and began to disassemble the sears unit. Cyl bore is perfect, bearings have no play. Thought I'd see really bad piston rings. The compression rings end gap is .015 and the oil control rings around .026. Does this sound excessive enough to be causing the oil to get into the head and out into the tank or not? (Crankcase vent is open) Could the oil rings just not be doing their job even if that clearance isn't excessive? I can,t think of any other excuse for the oil. Think I'll be able to find replacement rings, and maybe reed valves as well. Also, any good/safe way to get that oil out of the tank? Anyone have a similar experience?
