FWIW early in the thrd , the comment was made suggesting V ways more accurate than flat ways ...i do not THINK that is accurate ...early shapers were almost ALLw/ box ways ...in the past few years some mills have used box ways & touting THIS as superior PRECISION.....
flat /box ways require double gibbs , & w/ modern manufacturiing , V ways may be easier & cheaper to construct.?????? (two surfaces to grind ( or earlier , 2 to scrape ) rather than 3-4 + double gibbs ..
.Atlas /sears advertised specs were to a thou. for the LATHE ....CERTAINLY ADEQUATE FOR HOME SHOP OR LIGHT INDUSTRY AT THE TIME ...... even today when near all in industry goes to th e grinder for finishing ..
when considering purchase , one shud think carefully abt resale due to the widespread atlas /crftsmn predjudice , much of it unwarranted......BUT some things ARE AGGRAVATING ..cast iron & bronze can be REPAIRED ...broken zamak castings are another story to restore to factory specs...& the cheap supply of factory replacements is for all practical purposes non existant ..they were REALLY cheap at one time ... way more so than SB /Logan .......so when breakage of zamak occurs , almost ALWAYS from operator error ( zamak is much tougher than pot metal ), one cannnot get out the torch / bronze rod & repair ...& that IS a real PIA ..
.i have a a pre civil war shaper in use in my shop ...over the years , bronze bushes & brazed replacememt of broken parts ( again operator error ) have kept it fully functional ....same w/ an 1893 millers falls power hack saw....no need for $200 precision ball/roller bearings........or inflated priced ebay parts
best wishes
doc
best wishes
doc
