I am needing to make clearance holes for screw heads in an aluminum heat sink with fins (see photo). I am going to use a two flute mill to make the holes in the fins down to the heat sink base. Should I make a single plunge pass with a 5/16 end mill or work up to 5/16 diameter using smaller diameter end mills? My concern is bending the thin aluminum fins when the end mill makes contact with the top of the fins.
