Screw for drill Press vise
That's cool,hope someday to due Haifa the things u guys do
Scruffy
Really nice work... I am not sure how you formed the ends with an old router bit. I am a newbee. Could you explain please. Thanks!
Here is a shot of the router bit setup , it's simply some 1/2" key stock center drilled for a 1/4" inch hole with a setscrew added to hold a bit in place. it can be used for many different profiles depending on which bit you choose.Very simple , just try to line up the cutting edge on center. Thanks for the positive commentsIMG_1258_zps2b486562.jpgIMG_1258_zps2b486562.jpg
Wow.. Thank you for posting the picture which show how you did it! Really fine work.
any special router bit EG: carbide or do "regular ones" hold up on steel???
