- Jun 19, 2024
- 8
Hi folks, new member here.
My main hobby is airgunsmithing, which got me into lathes.. now I have 5 lathes, so I think it's my new main hobby !? Except for a chinese 9x20, all the lathes are smallish pre-war... a portass, a winfield, and two 10Fs. One Altas (a vertical 36") is in nice shape, and I use it a lot for metric threading. The recent addition, is a rear ountershaft 48" long babbit bearing model, that's going to need some TLC...
The carriage wheel felt slightly strange, and I suspected the gear cage was broken.. sure enough, I just got into it today and one tab was broken, so I'm milling a small lump of ali and bolting/JB welding it on the side to effect a repair. Half nuts are pretty good, so I don't think it's had much use threading, and the bevels/gears for the crossfeed all look great too.
The ways aren't too bad, but noticably tighter towards the headstock, so I need to wittle them down a fraction... not sure how best to approach this.. scraping is going to be a bit much, and I don't have facilities to get a really accurate surface level. Might just drawfile it !
Will have a look at the bearings too, but not really sure what to look for with babbit, unless they are really torn up.. and no idea how I'd replace even if they were ! The Timkin rollers on the other Atlas are much easier to work with...
The direction selector for the leadscrew is fine internally, but the knob is missing it;s detent arrangement to lock into position.. I doubt spares are available, so might have to make something - anyone done this before and have any tips ?
Any advice welcome.. I'm not looking to go a full resto... I just want to get it functional, mostly for threading or machining long barrels.
A few searches over the years have landed me on this forum so figured I'd join, say hello, and get the benrfit of all your experience first hand.. not sure I have much to offer in return, unless you are intested in the obscure English lathes![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks,
JB
Thanks,
JB
