- Oct 18, 2016
- 2,872
I finished a dial recently and did it the same way as you did, but yours came out better looking than mine.
Wait for me to screw up stamping the numbers before we compare dials...
For the DOC I went .010 and then turned a few thousandths off the OD to clean up the burrs from scribing. Did you use carbide or HSS?
I used carbide (because I had them), but next time I would use HSS. I broke the tip on the carbide tool backing out after a pass, so after that I had to retract the tool each time.
I can see why your lines look so good with the clean up pass you made. I used a very fine foam backed sanding
pad that I use to polish up parts. They create a better suface finish, but they don't really remove any material to speak of.
