Sandblast cabinet tips/ideas/plans
So I've came up with (What I think) is a perfect plan for a homemade sandblast cabinet, Benny & I did a little horse trading and I'm gonna end up with a Mazda B2000 truck cab with all of the glass in it and both doors. All I'll have to do is make the bottom chute & a frame/base to hold it and roll it around.
Should be plenty big enough for about anything I would need it for, plus it could be used from front or rear as suggested earlier. If I need to do something really long I can roll down the windows.
It'll be fine as long as you paint it orange.
If you do you better not butcher it into a sandblast cabinet ..... But if you ever find 2 of them you could cut them right behind the drivers dore and weld them back to back & have the coolest 2 way car ever
I did see where a guy used the rear portion of an old VW van to make a sandblast cabinet
Avoid sand like the plague. There are any number of suitable blasting medias out there that are cheap enough. Silicosis will kill you
Cheers Phil
There are problems with all the different media once they get pounded to fine dust levels :dunno:
You just have to practice the best safety you can. Dust wise in my shop it could be aluminum polishing dust from a cylinder head, sanding down a dental chair for repaint, grinding stellite valve tips, or the woodshop we keep upstairs. Not to mention all the various chemicals/smoke/coolant mist in the air depending on what is being done at the time.
I am installing a pair of 9700CFM exhaust fans in my shop, I had 9000 total CFM in my last shop so doubling that will be sweet. They are not cheap but well worth it.
