- Oct 29, 2012
- 1,392
I want to make a torqe-sensing PTO shaft for my tractor. I don't want a pony brake dyno or anything similar, I want to measure PTO torque and speed while running actual PTO attachments. To do this I think the simplest way is to measure twist of the PTO shaft. This is how it's done in industrial settings:
So contrary to the norm, I want the maximum safe amount of twist. This will make my measurement less challenging. I've calculated some values for hollow tube and solid rod, and for my target maximum torque over a 5ft shaft I can get 20+ degrees of twist, but I have no idea if that's safe, or one the verge of turning into a pretzel. Is there any way to figure the maximum safe amount of twist?
