- Dec 2, 2012
- 1,780
If I could only afford one, I'd buy the larger test bar for the headstock. A sleeve is probably accurate enough but will more than double potential errors (two mating surfaces for grit/burrs/whatever to cause you to pull out your hair).
The tailstock is far less critical IMHO. Drills and reamers will tend to follow their own path anyway (you'll need to use a boring bar regardless for accurate holes) and the tailstock is adjustable for cutting/not-cutting tapers when turning between centers. The spindle taper you want dead nuts aligned to the bed ways in both dimensions (horizontal and vertical, maybe ever so slightly pointing higher toward the tailstock — a few tenths over 12" at most).
A taper test bar isn't a mandatory tool unless you have reason to distrust the accuracy of your lathe (or are planning to rebuild it). It's kind of a one time use tool. (But I own both!).
Yeah , I think you are right about the sleeves, I have had my head stock off before but it does sit on the ways for alignment so I might just use the button on the face plate method fof double checking it and call it good.
Although a shiny test bar ? who could resist that ? I will just keep my eyes peeled on ebay unless I find plenty of spare cash in my pockets for some reason
(although the power hack saw motor rewind is priority for cash injection currently)
Stu
