RalphSounds like you are losing the set on the teeth..
Maybe I've never known exactly what I'm doing, therefore I don't know exactly what bandsaws are really capable of. But my experience has taught me not to expect any precision from bandsaws. For me, the blades walk worse and worse the duller they get (as mentioned) but they also walk a little brand new. You can do these things to help it cut straighter:
But even after all that, you're going to square it up in a lathe or mill. Or at least, I would. I'm sure somewhere there's someone who can bandsaw cut parts with machine tool accuracy, but it ain't me.
- install a wider blade (not talking about thickness; talking about the dimension from cutting edge to trailing edge) - If you can cut small circles with it, it's too narrow.
- Tighten your tracking adjustment rollers
- tighten your blade tension
- decrease your feed force
- Use sharp blade
A while back a thread appeared here on converting the Harbor Freight hand held metal band saw to a little bench unit . I did my own version of this and can report I have had good results. I did replace the HF blade with a good US one. An example of how well this little devil will cut...I needed some 1" wide x 18" strips of mild steel for a car seat frame. All I had was 90 degree angle stock, about 1/16" thick. Being cheap and stubborn I decided first to try eliminating one side completely with my HF mill drill/carbide face mill. Yikes, it worked, but took forever (probably cause I am a newbie) Anyway I did piece 2 and up with my little band saw and the 3 pieces were done in 1/10 the time !! I fitted an HF foot pedal to the little band saw so that both hands would be available for guiding the stock. I used the waste (vertical) side as a kind of guide and only had to do a little touch up /debur with a pedestal grinder. FYI
Edit: I hope this is not a "hijack." Just trying to relate to the general subject.
I doubt it. I don't know exactly what kind of motor you're dealing with but it's probably a single phase induction motor, for which there is no good method of speed control. You could upgrade to a DC motor or a 3ph AC motor if you want speed control.Is there any project where someone added a variable speed drive to this motor?
