I recently purchased a 5.4hp lathe and 3hp mill. It came with a 5hp RPC which is too small. Not sure how the guy that ran the equipment (deceased) was able to effectively run it with that small of a RPC? I’m wanting to upgrade and go with either a 15 or 20hp RPC. I have access to both size motors. I’ve spent the past few days reading and researching on building or buying. There’s a lot of info out there and some of it’s conflicting. I’ve read that one should go with Fitch’s design and I’ve read that Fitch’s design has shortcomings. I’ve read that one should utilize a pony motor and I’ve read that using start capacitors is the better way to go. I’ve called American Rotary and inquired about a system. They recommended purchasing their ADX-15 system and didn’t seem interested in helping me in any other way. Since I have the motor, I basically have two options from an economical standpoint…one is to purchase components and build the panel myself (assuming I can find the ‘right’ design) and the other is to purchase a panel built for the motor I have. American Rotary would not do this, it’s all or nothing. Is there any other reputable company out there that will?
