- Jun 7, 2013
- 10,452
Or, you could grind a lesser clearance angle on the front of the tool bit.You may be right. There's an inherent compromise in the design. A More vertical tool requires either less meat in the holder, or more stick out otherwise the tool holder rubs. And it puts more strain on the retaining set screw.
I picked 15 because the others I saw like this used 15. It may be better at 10, and is certainly cheap enough to try.
