- Oct 10, 2018
- 545
I have a small bench grinder and it took a whole day to grind these tool.
No tool should take a whole day to grind. A coarse grinding wheel that has been freshly dressed should remove metal at a pretty good clip. I wonder if your wheels are too fine or glazed over. And you don't have to worry about over-heating good quality HSS (unlike high-carbon steel). In fact, a wheel that is cutting well doesn't heat up the part nearly as fast as a glazed wheel will.
Craig
