Any recommendations of things to try here in regards to turning a better finish? As I was advised in a post about some different material, it's possible that the tool tip is not rounded enough but I don't yet have the knowlede of making one.
current set-up:
- lead screw turning at .0024, as slow as it can turn
- spindle is at 380 RPM.
- steel is a 1" hot rolled bar I had laying around
- I'm using a new HSS insert with some cutting fluid
Maybe it's just meant to be with this particular steel... I'm new at learning feeds and speeds so it's probably also operator error. I'm just looking for any recommendations to try. I did try cutting it at 540 RPM to no improvement. Should I try upping the spindle speed even more? The higher the speed, the more scared I get! Happy Friday! -John
current set-up:
