- Feb 16, 2017
- 136
As my signature says, I have a Rotex RM-1 horizontal mill with Rusnok vertical head. It has served me well.
This weekend, the x-axis power drive quit working, fortunately it happened at the end of the project I was working on. A quick look confirmed that the drive gear mounted on the lead screw was worn to the bone. It's a worm and worm gear combo. 10 years of use after I bought the used machine. Fair enough.
I know this needs pics so I will add these later as I move through the repair.
I have never found any documentation for the RM-1 so I am on my own as far as I know.
With the help of the Boston Gear documentation, I am confident that I have identified the gear as a 14.5 PA , 12 DP, 20 tooth, left hand worm gear. The worm itself appears to still be serviceable, unlike the gear. Possibly an earlier replacement by the previous owner.
I have found a Boston gear #1050ALH stock gear that is close enough (in regards to hub, etc) that I think I can make it work with some help from the Atlas lathe.
I will need to bore it, put a keyway in, and drill/tap 3 holes. I may need to turn the hub OD. There is 0.013" conflicting info on that aspect so we will see when I get the part in my hand. The hub is 1/8" shorter than the original which used a cap washer screwed to the face of the hub to retain the gear in its housing. I plan to make a stepped washer to replace the flat one. More Atlas work which will involve the deepest parting off I will have attempted as of yet.
I hope to get all the pieces and tools in place for Thanksgiving week since I have a few days I can spend on it.
The new things for me will be boring to a diameter and cutting a keyway with the lathe.
I'll keep adding stuff to this thread since there is no Rotex brand section as of today.
EDIT 11/12/17. I got corroberation of the above gear choice later in this rebuild. I was cleaning the parts in the washtank and found that the worm had a Boston Gear logo and part number GH-1056L on it. In the new catalog it is GH-1056LH which is a match for the gear I selected.
