Going to revive this thread instead of starting a new one.
For anyone that used the 6” rotary table on the PM25 I have a couple more questions.
1. Did you leave it on there or did you take it on and off when needed?
2. Is there any concern for table sag if I were to leave it mounted side by side with the 4” vise?
want to buy a 6 or 4 inch rotary table to use on my pm-25mv mill . has any one used a 6 inch on the 25 , is it too big ? or would a 4 inch be a better fit ? thanks john
p.s. what brand did you buy.
I have a 4" I used with my drill press when I was using it as a mill, it was one with a bit better quality but I would not buy another. I have a 10" Vertex and would recommend the Vertex brand to all, it is a joy to use.
I use those components on a PM727v which I think is similar in size and do not leave the RT setup. It seems to get in the way of the vise and doesn’t take that long to set up. If I do have both set up, I’ll have the RT as close to the vice as possible and leave the table centered to minimize sag effect.
