- May 3, 2020
- 153
Hey all, I have a question regarding theory of operation with a rotary table. Machine is a standard knee style mill. Here is a section view of a part I am interested in making that I designed (possible customer paying job, don't have full confirmation yet but trying to plan everything out in advance):
The bores are both 3 inches, although the upper bores are angled 5 degrees. I do have a tilting rotary table that I am planning to employ to aid with this. For the straight bores I planned on using some kind of 2 7/8" annular cutter/hole saw/etc to knock out the bulk of the material through the whole part while cutting the smaller ID, and then using an endmill with the rotary table to finish the bore, easy enough right? I figured I would do the same thing to finish the angled bores until I realized that the rotational axis of the table won't be aligned with the bore axis if the part is fastened flat to the table. Once the rotary table angle is set to 5 degrees, I wouldn't actually be able to make a circle with an endmill because the part would not be rotating about that bore, right?
Initial thoughts on how to overcome this are to use a boring head for the angled bores with the rotary table holding the 5 degree position. Definitely an option but kind of slow and fiddly, and I would be making four of these pieces total.
My second thought would be to make a basic 5 degree fixture plate/block that I could secure to the rotary table and then the part to that, in order allow the bore axes of the part and rotary table to align, and then go forward with my original approach using an endmill.
Third idea would be to employ a sine plate instead of a one off fixture in conjunction with the rotary table, although I don't own a sine plate (maybe a good excuse to get one?).
Am I on the right track here? Totally overthinking this? I would welcome any advice/feedback!
