- Jul 2, 2014
- 7,594
I would just go with 90 teeth, like on many commercial models. Then you can divide the four degree (240 minutes) revolution of the worm up more easily.
In that case you are starting to talk dividing head rather than rotary table, which is fine, just different. Dividing heads divide evenly, Rotary tables dial in degrees, minutes, and seconds as desired. Some rotary tables are equipped with dividing plates on the worm shaft, which also make them useful for dividing.I must be missing something because I can't for the life of me see any advantage to using degrees and minutes. How do you mark the handwheel dial? Do you divide it into 240 parts? I think that I will go with a 72 tooth worm gear because using tenths of a degree and 5 degree increments is easier for me than trying to deal with degrees and minutes.
