- Feb 15, 2020
- 404
WARNING! Programming Stuff Follows!
After some sleep loss I have some working code with error correction.
I had to do some extra stuff to move counter clockwise because if you step backward past zero degrees the original code failed.
I'll be back to explain this after some chores.
Eric
Code:
case '3': // Rotate CW
newKey = false; // Clear key flag
if(MotStat == true) // Do this if motor is on
current = current + Degrees; // Add new degrees to current total
if(current >= 360)
current = (current - 360); // Keep it under 360
CSteps = 0;
if(current == 0) // Prevents "0/360" error below
ToMove = Degrees * (Multiplier/360); // Figure out how many steps to move
CSteps = 0; // Reset cumulative step counter
else
ToMove = (current/360) * Multiplier + 0.5 - CSteps; // This is where the magic happens!
CSteps = CSteps + ToMove; // Add moved steps to step counter
// More stuff follows to move table and update display...
Code:
case '1': // Rotate CCW
current = current - Degrees;
if(current < 0)
current = (current + 360); // Add new degrees to current total
CSteps = (Multiplier - CSteps); // Add table steps/rev to total steps
CSteps = 0;
else
ToMove = CSteps + 0.5 - (current * Multiplier)/360; // More magic!
CSteps = CSteps - ToMove;
Eric
