Thanks Randy! This is the first I have ever used a rotary table. Most of my machining had been with CNC equipment. But I always enjoyed manual work when I had the opportunity.
Today I clamped the plate to the table. Indicated it true to the axis of the table.
Then I milled the plate tru to the surface of the table. This Chuck has two bearing surfaces that are .032 difference in height. That is the reason for the two different surfaces.
