Rotary tabel and 4 jaw chuck
You don't need a co-ax to indicate any of that. A co-ax indicator is just a convenience. Some people don't even like them or own one.
Me for one . :) If I had one indicator to go with , it would be a Bestest .0005 . Back in days of setting up Deckel jig bores , we used dti's with .00005 grads and we still missed on some true position specs with them .
Nowadays , I could use a wiggle stick and it wouldn't make a difference . :big grin:
I centre my table by mounting the indicator on the table and indicating against the spindle by rotating the table. You avoid any potential issues with features at the centre of the table not being concentric that way. When setting parts in a 4 jaw on the table, I then mount the indicator to the spindle and rotate the part with the table. Pretty much my method is "rotate the table".
Your process ought to work, but sounds like a feature you're indicating off somewhere in your setup isn't quite concentric.
I use a "noga arm" with mag base and a Mitutoyo 0.0005 test indicator for pretty much everything. For spindle mount jobs, it's one of the cheap jointed arms that clamps around the nose of the spindle.
Sorry to hear about you coax!
Center table by turning a tapered plug the size of the center hole and mounting that plug in the mill like it was a burr. Set the table to fit the plug as snug as a bug in a rug and lock it to the X-Y table.
Never trust any runout reading that is zero. 9 times out of 10 a zero runout reading is the indicator beyond range.
Are we talking 10 thousandths, or .010?
How far from the face of the chuck is the reading taken?
I also made me a centering mandrel for my RT & chuck. Good enough for me for most uses.
