Hello, ty broomstraw, it seems alot of powder is getting hard to find, will check these powders out got to make a trip to the powder house tomorrow and i will see what they got. ty much mac
I can understand not wanting to have a powder supply store with all of the different powders on the market. It has been my experience over the years to consider burn rates and also powder density. The responses about checking out the web sites that have load data are a great place to start. Will also depend on if you are using these loads for target, hunting, or defense.
My go to powder for most of my larger caliber reloading (30-30, 30-06, 35 Rem, and others) is IMR 4064. It is has the Blue Label. This powder will give you lower pressures and great results. It is a very universal powder with good load density. It is also a very clean burning rifle powder. There is data for this powder on Hodgdon load tables. Over the past few weeks it is a little harder to find, but it is out there. Saw some this past weekend for around $25.00 a pound. A pound will give you between 150 and 250 rounds depending on which caliber and how 'hot' you want your loads.
One other one you may want to look at is Varget. This is an Alliant powder. My local reloading supply store says it is the most popular rifle powder. I have looked at some of the data and it does look pretty good. It is just real hard to find right now.
If you are going to mainly shoot cast bullets, my suggestion is use gas checks. If you do not use a gas check, keep your velocities below about 1600fps. (This may be a little high for some people, but I cast my bullets with a Brinell of about 20.) There is a wonderful site on using 'pistol powders' in rifle calibers. The site talks about using 10 grains of pistol powder and having great results especially with cast bullets. He has done lots of studies with different calibers, powders, and bullet weights. If you try this, please read ALL of the warnings that are on this site.
