ACT:4
Since the roughing was completed in the lathe, it was time to move back to the Ammco 7" shaper.
I was toying around on a piece of 1.5" delrin on a 3" rotary table attached to the shaper's box.
i was able to start making a hexagonal piece.
this was merely a test to see if the rotary table could take the forces of the shaper.
while not ideal, it functioned
i used the shaper pallet i made a couple years ago, you can see it here:
I reclaimed some aluminum from a casting from a Hobart Meat Saw. the part is considered consumable by the manufacturer, so i get about 6 or 7 of these castings a year on average i have used the aluminum for all kinds of beating devices and press plates and spacers. this time a clamping pallet...
www.hobby-machinist.com
i had to drill an extra mounting hole in the pallet for mounting purposes.
(i usually hold the pallet in the vise, but didn't have the headspace to do so on this phase)
i mounted one half of the articulation joint i was creating on the rotary table and took some test cuts!
i found out i could only take light cuts when the part was oriented in this way.
the chuck started to loosen if i put any real pressure on the cut
, (hence the blemish seen below)
so i turned the part 180° to prevent the problem.
as i started to shape the billet, i raised the part on a sheetmetal shim so i didn't run into the rotary table jaws.
i changed to an insert finishing tool and made more progress, shaving off .005" per cut, then switched to a round-over tool to make the corner smooth
i switched the rotary table out and switched back to the finishing tool.
i mounted the articulation half again in the vise and took some finishing cuts!
more to come.....
