Retrofitting a used heat treat oven with a new PID
I put a PDI on my Bradley Smoker. Much easier to control the temp rather than using the cheap slide temp switch that is on the smoker.
My oven has the elements buried along the walls in the stone. It’s rated for up to 2000 degrees aswell.
I’d also like to put a new controller but the old school control is working fine as of right now.
@seanb - would you be able to provide the interior dimensions for this unit? One of these popped up local and I'm debating buying as a heat-treat oven. Did you ever attempt the PID?
So what will be the primary use for this? Knife making? I assume you are treating steel?
I use mine for annealing steel. Also some case hardening and hardening of air and oil quench steels.
