- Sep 5, 2014
- 428
The TWS was the worn out one. It had guide posts on the outside of bow frame instead of on the inside like the more common Rong Fu style. They were also longer so you could get the guide rollers closer to the work, a good thing with metal bandsaws. The bearings were also bigger, I had replaced them before I tore it apart! so I couldn't use them on the Rong Fu. oh well.
What was better on the BusyBee/Rong Fu was the slot for the T-nut. On the backside it was machined instead of rough cast. On the TWS it had chewed up the T-nut pretty bad.
My emphasis was on the vise, on the worn out one, it was as rigid as a fish in the bottom of the boat. So I had no hope of squarish cut. As well as the spacer on top of the T-nut, I added a thrust bearing to the rod. To but against something square, I JB welded a brass washer 90degrees to the rod. Instead of a thrust bearing another 7/16" brass washer would have worked. The rod is a 5/8" LH thread Acme and the handle section is machined down to 1/2"
The Rong Fu cuts square when I put a .040" x 1/2" shim beside the blade. chuckle. I'll call that project machine is finished.
