- Apr 12, 2013
- 562
Another problem with flipping it is that 2-1/2" of the right end is 1/2" dia. When you flip it, you have to cut that off as the left end of all Atlas 10" and 12" lathe lead screws are either 5/8" or 3/4" dia. So you will have to relocate the right bearing about 2-1/2" to the left.
On very close inspection there appears to be a sleeve around the leadscrew where it enters the QCGB. The right side bearing is about as far right as possible...no signs of remounting (empty holes in empty real estate sufficient to account for the extra length mentioned above). There is, however, plenty of room to the right of the rack gear to do this if desired.
