So in neutral the belts and motor run perfectly smooth at full speed. I checked the tension of the belt and it felt fine. Seems like if it was the belt being too loose I'd get some slippage even at low speeds when i'm turning something lets say aggressively and I've never had any issues with speeds 0-300.
Not necessarily, remember it’s not a chain with a bit of load it will stretch and jump over from the video it was rattling to much pinch it with you fingers it should not move too much
