- Sep 28, 2022
- 186
First, I would ask if you have a schematic of the headstock breakdown, or even better, the spindle parts breakdown. This might help determine what might be missing or not tight. I agree with others that this gear should not be moving anywhere near that much. Typically gears on the spindle do not slide for shifting, rather they are under compression.
There are a couple of things I would check. See if either a spacer or retainer is missing somewhere in the stack. The other is to check if there is a lack of compression of this assembly – meaning a take-up nut for the spindle is loose. I would check front and rear spindle bearings for deflection.
If you do determine something is missing, more than likely the spindle would have to be pulled. But even if it just needs an adjustment, you need to be aware of the procedure for adjusting and setting preload on a spindle.
Let us know what you find out.
