Replacement Logan cross feed dial (big snough for old eyes)
Finally got some time to putter around and got started on the "inner" dial. 3.25" 4140 turned down to 1.60". I was a little worried about turning the 4140. The only issue was an issue I created when I installed the new motor this spring. Hogging off the 4140 made me stop and readjust/correct the issue. Yes I could have saved some metal and designed this with a pressed or threaded 0 - ring ... but I got a good deal on the piece of 3.25" stock.
Still need to clean/square up the flange. Then plan to drill a starter hole for boring bar and cut off this portion so I can chuck it up on the 1.6" end to bore and finish off.
Open to suggestions if anyone has them.
Better get a big bucket of popcorn ... I aint none too fast.:whistle:
Ok, Redlineman ... I told you to get a big bucket of popcorn.:whistle:
Had a chance to putz around the last couple of evenings. Here are a couple of progress pics.
